would this run on pump gas?
That motor *should* be happy withg regular. 9.1:1 is hitting the margins for most engines with cast iron heads. But you can run higher compression with AL heads before preignition/detonation becomes a problem because the AL head sheds heat from the combustion chamber quicker.
The octane you need is determined by several factors, including; timing (static and total, compression, operating temperature, fuel/air ratio, head material, camshaft profile, and even intake and exhaust systems. Probably some others that I'm forgetting.
Mark...
Yep
It will be fine on pump gas. Shouldn't have problems until up over 10 to 1.
That is basically the same motor I have in my cruiser, except I'm running a bigger cam/carb and different intake.
JR
