Worth disconnecting the swaybars?
Spicewood, Texas
Took her out and did some flex tests today to meke sure the 35's will clear. I can't help but think the sway bares are limiting my flex. I'm running a 3" Allpro lift with Walker Evans up front and spacers in the rear. Could it be the shocks in the rear? The good news, no rubbing with with 1.5" wheel spacers and body mount trim!
I've pulled my swaybars front and rear. It helped, but not by much. If you are after max flex, then do it.
The rear shocks are the limiting factor for the rear. You can get longer shocks, but then you need to worry about the coils falling out. That's my next mod....
