The rear flange on my transfer case has some up and down movement, but when I move it up and down, the visible end of output shaft appears to stay still and not move. The washer behind the nut also moves... so it appears that the nut isn't tight against it.
Does this mean my flange/splines are maybe worn?
I've looked at the manual, and read a few posts describing how the rear bearing retainer and shims determine the preload/tightness of the output shaft bearing. I may still not fully understand correctly?
