Work around when converting more than 3 images to full screen with IE
Brisbane, Australia
If you are having trouble converting more than 2 thumbnail images to full screen in one post with IE, the trick I found is before you hit the full image button hit the Enter key to more your cursor to the bottom of your dialog, then after each button push on the next full image button hit the enter key so there is a space between each image.
For some reason IE is not formatting each image properly unless there is a space or the enter key is pressed between uploads to full image.
