wont turn
spicewood,tx.
1975 (whatever) fj40. occasionaly lately this thing will not turn over. sbc , etc. i can easily jump it with a wire from the battery to the starter solenoid, and it will start right up. ummm. now that i am thinking about i usualy happens when it is hot.
i'm thinking the switch on the column. i know i can put one of those push button switches on the dash to cure this , but would rather not. any ideas?
jim:frown: :beer: :beer:
You check the wiring or the solenoid??
mace
the solenoid is good because when i jump it starts. wiring is the question. have any of had a failure of the ignition switch? really don't know , just looking for ideas.
jim
I've got your solution... My 40 had the exact same problem. Mine would not turn with the ignition switch. All it would do was make a click sound from the starter. The PO had also installed a push button start to fix the problem, so I went ahead and purchased this from CCOT.
http://coolfj40.stores.yahoo.net/igcabswitfj1.html
Heat sink maybe. Chevys have been known for this problem. Truck starts fine when cold, but after a long drive or on a really hot day the car won't start. Usually happens when you stop for gas. It's because the starter is so close to the exhaust. I resolved the problem on a truck I used to have with a starter heat shield. Summit or jegs has them. They bolt up around the starter and have a piece of insulation to protect the starter. After I installed mine I didn't have a problem.
My bad madoc1, i thought you had a 2f.
