1996 LX450
Basics:
74k
New Parts and Maint.: ( all new parts and work have less than 10k most under 5k)
Belts
Air Filter
Plugs
Wires
PCV Valve, Grommet and Hose
Brake pads Front and Rear
New Battey
Blue fan Clutch
Installed Auxiliary Pusher fan on Condenser
New u-joints on the front and rear (Toyota parts on front, spicer on rear)
Rear shaft balanced at Austin drive train
Radiator cap
Thermostat
All new seals on front axel (Toyota parts)
Rear inspected (checked out fine)
Throttle body cleaned
Mobile 1 in Front and Rear Diff
Mobile 1 in Transfer case
Mobile 1 in engine
New bulbs in dash lights including “D” light
All four Rims were stripped, re-machined, painted, and cleared ( they look brand new)
Radiator was flushed and filled 2 times with a generic coolant, then flushed and filled with Toyota RED COOLANT
New exhaust from the header back
New o2 sensors
So what it is doing.
Sometimes prob. 1 time in 5 when starting the car it sounds like the battery is going dead. If I crank it a few times it turns over.
I have had the battery check.... Good
I have had the alternator checked....Good
I have had a couple starters go out in my life and that does not seem to be the issue, as it still tries to crank. Every bad starter I have had has just clicked or done nothing at all.
Any info or links or if someone could tell me what to search I would very much appreciate it.
I can't afford to throw parts at this rig and with 2 jobs and no days off I have very limited time to diagnose the prob.
Basics:
74k
Belts
Air Filter
Plugs
Wires
New Battey
Blue fan Clutch
Radiator cap
Thermostat
Mobile 1 in engine
New o2 sensors
