- Joined
- Sep 1, 2007
- Threads
- 34
- Messages
- 588
Don't like the lateral axle movement with the panhard.
Thinking of fabing a WOBlink to replace it. No lateral axle movement plus it is compact with good ground clearance.
A triangulated 4 link would be a PITA to do in the 80 around the fuel tank and everything else. Going WOB would loose the lateral movement w/o having to redo everything.
This cruiser got a Watts link.
http://www.4wheeloffroad.com/brandpages/toyota/131_0307_1976_toyota_land_cruiser/index.html
The horizontal watts linkage might be even better at allowing travel, articulation and checking lateral movement. Would not execute it exactly like that however.
A satchell link setup might work out. No seperate lateral links. Angle lower links inward. http://www.automotivearticles.com/123/Suspension_Design_2.shtml
"The best location for the angled arms is the Satchell link design. This configuration puts the angled arms below the axle and pointing in. With a Satchell link rear suspension the designer can achieve a low roll center, good anti-squat, good support for the axle, and there is no need for extra chassis bracing. Also, the Satchell link is compact and can be squeezed into applications where other styles of live real axle could not be made to fit."
I like it. A set of off the shelf adustable upper arms can even be installed first. Then Fab boxed lower arms and a new frame mount.
