Wobbling FJ80
Alamance County, NC
replaced rotors, pads, lines ~ 2 years ago. They were expensive aftermarket rotors made for heavy duty use. Now I notice lots of shaking on front left wheel especially upon hard braking. I did not replace bearings when I did the rotors. Lifted truck last night and front left wheel has play in and out from truck. What do I need besides a mechanic who knows what he is doing? Where do I get the parts?
FJ 80 wirh ARB bull bar, warn winch, and side rails. Lots of off road use. Not lifted, stock michelins.:crybaby:
Thanks you
First you need to properly preload the bearings on that side. That will stop the shaking for now, but you need to get in there and inspect the bearings and spindle. Probably best to go ahead and replace the bearings and races.
You need to open it up and see what is possibly loose. This happened to me 2-3 years back after doing the birf job. I had forgotten to bend the tabs on the star washer. Everything was fine - just had to have the rotor turned. Nelson
Hey! as far as that wobble goes....I just did a knuckle rebuild and birf repack as a 200k service. I was really glad that I did because I found that the studs that were on the bottom of the knuckle that hold on the steering arm were backing out. one was gone, one had only one thread holding it on and the other 2 were loosening. That could have been REALLY bad! it felt like a warped rotor would but shook the steering wheel slightly more. I went to the dealer and got new studs and everything is as it should be now. About $3 per stud and really easy to pop in.
