I have a case of 51068 filters for free..should I use them?
recommended filter is 51515 which is .8 inches taller, but same specs....
I am assuming that the 51068 is more in line with the current toyota offering and the 51515 is more desirable like the larger toyota filters??
Here are the specs
Part Number: 51068
UPC Number: 765809510685
Principal Application: Agco Tractors, Chrysler (70-91), Ford/Mercury (83-97), Kubota Engines, Land Rover (95-04), Toyota (68-90)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.338
Outer Diameter Top: 3.660
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=10/26
Burst Pressure-PSI: 275
Max Flow Rate: 7-9 GPM
Nominal Micron Rating: 19
Here are the specs
Part Number: 51068
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.338
Thread Size: 3/4-16
