WIRING SERVICE UZ - ENGINE SWAPS
LexusV8 Engines
Supporting Vendor
Website
www.lexusv8.com
LEXUS V8 WIRING SERVICE FOR ENGINE SWAPS
1UZ (vvti only), 2UZ and 3UZ Manual or Automatic - $590
Immobilizer Bypass - $150
ECU Flashing - $150
Air Injection Delete - $200
Various Connector replacements $5-$8 per connector installed.
-We wire up your harness so that you have 3 wires to connect.
-We also wire in your alternator oil light, rev count and temp gauge, as well as OBD2 where applicable. Where OBD1 is relevant, we wire it into your fuse box so that you can read flash codes.
-We build a fuse box onto your harness, so it becomes a standalone system on an OEM Management.
Simply send us your engine harness and ECU and we will make it a standalone system for your engine swap.
Please send email for customized quote for your project.
Best way to get hold of Tim is via email as reception in the workshop is very bad.
Email: sales@lexusv8.com
Website: www.lexusv8.com
Tim: 305 619 5355 (plse leave txt message if no answer)
Sally: 770 722 2345 (Admin)
LEXUS V8 ENGINES LLC - FLORIDA USA
