WIRING SERVICE FOR ENGINE SWAPS - 1UZ & 3UZ Lexus V8
LexusV8 Engines
Supporting Vendor
Website
www.lexusv8.com
LEXUS V8 ENGINES LLC
We offer a Wiring Service for Engine Swaps.
1UZ & 3UZ Manual and Automatic
You simply send us your Engine harness and ECU and we will wire it up so that you have 3 wires to connect and get your engine to run.
We will bypass your immobilizer at a small extra charge on your ECU if required.
We build a fuse box onto your engine harness so it becomes a stand alone system on an OEM Management.
We will also wire in your alternator oil light, rev counter and temp gauges, as well as OBD2 were applicable.
Where OBD1 is relevant, we wire it into your fuse box so that you can read flash codes.
We also stock a majority of the connectors and we will give technical help and advice.
Standard Wiring Job for 1UZ and 3UZ- $490
Bypass immobilizer 1UZ VVT- Manual and Automatic - $90
Bypass immobilizer 3UZ -5 Speed Manual and Automatic $140 and $150 for 6 Speed Manual and Automatic
Various connectors - $5 each installed.
We located in Florida, USA.
www.lexusv8.com
sales@lexusV8.com
Tim - 305 619 5355
Sally - 770 722 2345
