wiring issues...
charleston,wv
i bought a set of Hella 550 fog lights and mounted them to the front bumper. i have all the wires from the diagram hooked up to the right places from the relay and to the relay correct, only difference is that instead of using the parking lamps i used the low beams as the supply to the switch. i have tried several different areas for grounding for the relay because i have blown the fuse in the relay about 4 or 5 times now. used the ground for the headlights, battery along with the front panel as grounds.
what could be causing me to blow fuses, would using the parking lamps instead of the low beams or using both at the same time as a supply to switch make a difference.
The headlights in the LC are wired very weird. They are not just straight ground/positive. I can't remember the exact lay out, but it has to do with the auto off switch, where the headlights will turn off when you turn ignition off and open the door. I ran into problems trying to use the headlights as signal for my fog lights and when putting a volt meter to the headlight plugs got all kinds of weird stuff. I can't remember exactly, but it was something along the lines of positive power to both terminals when the lights were shut off. So if you have ground wire hooked up either of the terminals, it's going to blow fuses.
If I remember correctly, in the low beam headlight plug, one terminal always has power no matter what. When the headlights are turned on, the 2nd terminal is somehow grounded and the lights turn on. When the headlight switch is turned off, the terminal that was once grounded, now has power. The wiring diagram would probably explain this, but I dont have it in front me. Basically, the system has to be able to turn the headlights off, with the column switch still in the on position, there's a seperate cut off switch that affects how it's wired up.
Probably the most straight forward way to wire it if you want the lights to come with with parking lights is to plug the switch into the taillight fuse in the fuse box. Best to use a relay here, so the fuse isn't actually powering the light. Then whenever the taillights are on (which is when the parking lights come on) you have power to the driving lights and then hook that up to switch so you can manually turn them off if you need too. The taillight fuse powers (if I recall correctly) the tail lights (not stop light) marker lights and instrument lights. So basicaly when you turn the lights on to the first position, you'll have power to your driving lights.
I'll simplify Brian's explanation: Toyota uses a ground-switched system. Instead of the switch cutting off power, it cuts off the ground.
EDIT: Just re-read Brian's post. 91-92's don't have the auto-off like the later models, so my simple explanation may not be relevant to your situation.
i didn't even think about trying to use to taillights as a supply source, i've got some extra fuse taps from adding another power outlet laying around that i may try to use for this.
tried using a fuse tap for both the tail lights and head lights and blew the fuse both time, i'm going to recheck everything tomorrow.
Did you use a relay? The tail light circuit can only handle so much draw; driving lights will put it over the top and blow the fuse.
the hella's came with a relay and diagram, the switch needs a power source like the parking, tail, or head lights. the relay that came with it uses the battery for power, has a ground, has a hookup for the lights, and hookup that connects to the switch as a load.
i just tried using a fuse tap for the parking lamps, tail lights and head light for the power source of the switch. i'm still using the relay that came with the lights.
How To Wire Fog And Driving Lights Harness Wiring Diagram, here's a diagram of the setup i'm trying to use
Oh, I see. I build my own harnesses, so I tend to forget that the lights come with one... Are you using the correct fuse for the tail light circuit? 10A, IIRC...
There might be a short in the Hella-supplied harness. I'd snap a properly-rated fuse back into the tail light circuit and make sure the Hella harness is properly wired.
I assume there's a probably a lighted switch in the package. There would be a ground wire to allow the switch to light up when it's turned on. I'd guess the wires attached to the switch are mixed up.
If it's a lighted switch, there are probably three connections on the switch. One would go to ground, one would go to the relay and one would go the taillight fuse. I think the ground and relay connections are reversed on the switch itself, so that when you flip the switch, you're connecting the fuse directly to ground, rather than the relay and that's why the fuses are blowing.
That's my best guess.
Good luck
Here's some clarification on the headlights after I went back and looked at the wiring diagram. I was wrong in how I remembered it.
The high and low beams are wired differently. I was actually trying to tap into the high beams back in the day.
The low beam circuit has a permanant ground on each light socket with a switched positive that comes directly from the headlight relay and feeds through a fuse, before reaching the headlight. You should be able to actually tap into the low beam positive side as a signal switch, if you wanted too. The easiest way to do this would be to tap into one of the two headlight fuses. The relay will get power when the low "or" high beams are on, then turn off when the low beams are swtich back to parking lights or turned off, if you wire it that way.
So basically, if you want power to Hella lights with the first position of the light switch (parking lights) tap into the taillight fuse. If you want power only when the switch is on to either of headlights, then tap into the headlight fuse.
The problem I was thinking of is with the high beams. I was trying tie into the high beams to use as a positive side signal and that's not possible. The reason is, positive side of the high beam circut is always positive when the low beams lights are turned on, so the high beams are not indepedently switched on the postive side. The high beams are negative side switched. And now that I recall everything correctly, I remember that's how I have one set of lights wired up. The relay gets a negative signal from the high beams so a certain set of lights will come on and off with the high beam switch.
bought a new switch, burnt up the old one. there were two diagrams one without labels and small diagram for the new style switch it said. the smaller diagram for the switch had the supply from the switch and ground for the relay reversed, got that solved. couldn't get power from the parking, low beams, or tail lights to power from the supply of the switch. so taped into the rear defrost fuse and ran with that power source, it works and only when the keys are in the on position so i don't have to worry about leaving them on with the car off.
after about 12 fuses or more i finally got it all figured out.
