wiring harness conversion
I have a 75 40 and the po had put a tilt wheel from a caprice in it. looked like shat. :mad: so I have replaced it with a stock column/wheel and found that the wiring was all f-d up. I decided that it would be easier to just take the harness from my doner 79 lc and swap it in. I have it in now and found that all of the connecters are different, so I just swaped all of the dash switches and will splice in the tail lights ect.
I am also converting back to an asain 2bbl carb. not sure which model, but it only has one electric solenoid and no vacume activated functions(external). so I was wandering which of the emissions controll modules to use and if I even need them or should I put a toggle switch on the dash for the carb?
I am also running a gm hei big cap dist. thanks for any help!!!!
