Wiring harness connectors
Fayetteville, North Carolina
As I start removing my wiring harness the connectors are falling apart because they are so brittle. Literally falling apart. Is this common? What are my options? What did you do if this happened to you>
Buy the Black colored new ones if u can , there UV Rated and wont crumble into dust anytime soon
Most all my replacement wiring needs have been met by @Coolerman - super helpful/knowledgeable guy with a big stock of the right components.
I purchased a bunch from here - Vintage Connections - Motorcycle Terminals and Connectors - Vintage Connections
Quick shipping, fair price and good product.
Believe the OP has a 80. Didn't see anything on that website that matches many of the 79+ connectors.
I'll have to check 79 thought the connectors in it we're in pretty good shape. Know it's been in AZ for at least twenty years probably more with the lack of rust. Would have to check the title for transfer date but think I bought it from a friend in 1999. He kept it in a garage and I've had it in a garage or cover. So it has been in heat and low humidity but very little UV light. Has your wiring been exposed to direct UV?
Go with Deutsch DT series connectors. Not the cheapest, but the last you will ever buy.
Brian
Please post photos of witch particular connector housings / types u are needing
here are a few I need:
Since it hasn’t been explicitly stated in this thread, I’ll put in a plug for @RAGINGMATT
I’ve done business with him several times. He knows his stuff, has always been able to get me the connectors and harness parts that I’ve needed and, perhaps most importantly, has gone out of the way to make sure I’ve gotten what I needed.
