Wiring Harness Connector replacement??
I need to replace a couple wiring harness connectors (molex connectors?) I have the parts coming from Dan. I thought I had seen a couple posts on replacing these but I can't find them.
Are there more accurate terms I should use, or can someone provide some guidence ont his?
Well there is the obvious, make sure the wires go back in the right spots.
The wire terminals are released from the connectors in several different ways depending on terminal type size and sex, some have two latches, for instance many interior non water proof connectors have a plastic gate that has to be lifted from the side then a release that you reach with a terminal pick from the wire side, water proof connectors usually are released from the terminal side,
There is a wiring harness repair manual that details how each terminal type is disassembled, you can get this manual from the Toyota TIS website for $10.
Awesome, I have the part number for that manual. I think I'll order it from Toyota Documents to have a hard copy.
Somehow I knew it would be you answerting this question. Thank you again for your help!
