wireing from alt to iso.
Medford, Oregon
I'm wiring up an isolator with dual batteries, the problem is I don't see how to wire the alt to the iso. Is the wire from the alt a new wire that I need to add or is it an existing wire that I need to splice the iso into it. Please help.
Unless you want to select which battery you want to charge leave it as is, the main batt will charge all the time and the aux will charge when you have it on both, if you isolate the aux as in winching the alt will be out of the loop
Butch
