Wire loom under seat
While cleaning up the interior this weekend I noticed a wire loom running from the floor under the driver's seat up into the seat bottom. The seats in my 80 are non-powered mechanical seats. What is this wiring for and where is it going? This is in my 94'.
Thanks
Probably just the wiring loom for electric seats anyway. Our 80's also have a wire loom for a Center Differential Lock that doesn't come standard on US models. Probably the same wiring loom regardless of power or manual seats is installed. Just a guess. The control module for the factory alarm is also under the driver's seat.
CycloSteve,
Can you go into any details about which wires you used to power your seat heaters?
Have the pinout diagram at home...but overseas until Saturday. Let me know if you still need the dia.
Yes, please provide. Good info for future reference.
The pinout would be great and also can you verify that the wires you are talking about are the ones circled here:
If so I'm going to check with Mot to see if he can get the connector for it.
Wow, I am lucky. I was just contemplating installing seat heaters and stumbled upon this thread. I would be grateful for any info on the seat heater wiring:
1. Which connector it is under the seats
2. Where is the other end of the connectors in order to install switches
I assume that the wiring is already powered and it only needs a switch and a heater...
