I just bought my first 80 (locked) about 5-6 weeks ago (1994) and have a few posts re: it......I have not added pics yet or put it in the mud registery yet.....eventually the camera will work.....
I have an intermittent miss in the engine. I have R&R the plugs wires, cap, and rotor, and replaced the intake plenum...all OEM.....thanks CDan....... I was throwing a code 71. Bypassed the EGR as per the info here on mud. ( my suspision is that a wire or 2 is cooked by the EGR) I have done a search on how to explore/replace the wire harness by the hot EGR tube, but have not found any info regarding how to access it.......the EGR is in the way, so I guess I just remove it.......no problem.........BUT my big concern is as soon as I start unwrapping the engine wire harness and check for brittle wires, I am thinking I will take the chance if cracking more insulation....... trouble x2.....
informationjunky, I took the insulation off like you did and fortuantely all looked OK.
So now I just need to wrap it back up w/ some good insulation...
Found the source of the misfire......25-30 deg. of timing advance by the PO
Just can't figure out why it came and then went away for a week and then came back again when I put the OEM plugs in......I promise I did not touch the dist. until today.........I have been on a wild goose chase over this issue...... I should have checked the timing first.....why didn't I think of that......??????
Mine was pretty intact........a little crispy on the outside in a few spots, but like you said, at least I do not have to worry about my wire harness......At least I hope...... I wonder if messing with those wires is why my AC comp. will not engage. ??
It was working well last time I tried it....about 10 days ago.
