wiper motor
HOT ASS AZ
I was given a gift cert. to sor for xmas. was thinking of getting a new wiper motor for my 67 fj40. however, that would max out my gift cert. (100$) is there any other place that i can get a decent motor for less than that? also, there is already one working motor. if i have 2 diff. wiper motors, will that f**k things up?
Perhaps the non-working motor can be fixed. I just replaced the brushes in the motor of my '76. Cost about $5 for the brushes. Cleaned and lubed the whole affair while I was at it.
If the commutator is not destroyed or a winding open, new brushes should put it back on the road. Possibly bearings needed also. Just have to check it and see.
Let me know if you are interested and I will dig out the brush supplier info.
Todd Bull.
how do i know if it is the brushes or if it is something else? in other words, when i take the motor apart, what should i look for to tell if it is just the brushes that need to be replaced or if it is something else?
www.cruiserparts.net is a good place to check out. As far as electric motors go, you might want to find an electric motor specialist shop and have them take a look. It would probably be the best investment, and you could get the particular part(s) from $OR to fix it. Good luck!
When you open the motor, you can definitely see if the commutator is OK. If there is damage, it is apparent. You may or may not be able to see a problem with the windings. A burned spot and melted windings will definitely indicate that the motor is toast. Often, though, open windings will not be apparent and a micro-ohmmeter is required to verify a problem.
Usually, the brushes just get too short from normal wear. At that point, the brushes do not contact the commutator sufficiently. The motor will work intermittently for a while and then quit.
Nobody sells direct replacement brushes, but this outfit http://www.graphitestore.com/ sells tool brushes that can be sanded down to fit (look under applications, fractional horsepower). You'll have to measure the brushes for your particular motor, as I don't have one of the older style motors. You'll have to choose brushes close to the necessary size and style.
Due to cost, I replaced the wipers on my '66 with a single motor/two wiper setup from a later model. The gearboxes in that later model setup were caked with grease inside that had turned into thick goo that put too much resistance/load on the motor. Once cleaned, regreased and the cable lubed it runs fine. You might see what the "transmission" on your current motor looks like inside before you tear into the motor itself.
Ed
