wiper motor ground
Sunny South
just bought a wiper motor setup from a local ih8mudder, in great condition. i hooked them up and they didn't work ... theres power going to them but there not working? i will check the switch tomorrow but where is the ground supposed to be? does it ground it self when you bolt in on the windsheild....??? or is there an external wire somewhere
p.s.- Thanks WRT for the setup and nice 55!
stock wiper motor, top of windshield for your 71 fj40? it grounds itself to the windshield frame. Try grounding it with a wire to the tub if you think its not grounding itself. You could also run a hot lead directly to the motor to test if you suspect the switch.
good luck-
Dustin
I don't have my 68 or 73 in town but I do have a couple of these wiper motors laying around. Both have four wires in the plug. So I'm assuming that one wire is low speed, one wire is high speed, one is positive (+) all the time the ignition switch is on and the fourth I'm guessing is a ground wire. The positive wire is there keep the wiper motor running to the up position after the switch is turned off. The earlier and later wiper motors have a ground wire, I don't know why these wouldn't.
John
