Wiper electrical Problems
Power for the wiper motor goes straight from the fuse to the motor. The motor gets it's ground (return path) through the switch. The fact that your washer works is an indication that your switch has a good ground. Are you sure that one of the four connections at the motor plug is not hot when the ignition switch is in "accessory" or "run"? There is a plug at the motor and another, I believe, above the ashtray behind the dash. Make sure they are connected. If you have power on one connection at the motor plug but the motor will not run, your motor may have short (worn out) brushes.
HTH.
Todd Bull
Per the OEM wiring diagram, the light blue wire at the motor plug should be the hot lead (ignition switch in run or accessory), and it should be hot if your washer motor has power. If you energize the light blue wire and ground the light blue/black (high speed) or light blue/red (low speed), the wiper motor should run. If it doesn't run, then most likely it needs new brushes.
I think the second wiper plug is up behind the dash, just to the left of the glove box. You may be able to see the plug by looking through the glove box door. Removing the vent duct and the ashtray (both parts) would help you get a hand on the plug.
