Wiper blade "chatter" on windscreen
Australia
When I turn the wipers on, the first 3-4 sweeps the wipers sweep fine and then they start to "chatter" in both directions. I have replaced the windscreen, replaced wiper blade holders, used Toyota rubber blades, silicon blades, graphite blades. Cleaned the windscreen with various cleaners until it so clean it is sterile. Have tried twisting the blade arms in all directions within limits to no avail. Applied "Rainex" and added "Rainex" to washer water still no good. Have polished the windscreen with with polish still no good. The only thing that I can think of now is possibly the wiper mechanism but when I saw it located behind the dash I had a minor cardiac. I am open to any suggestions. The vehicle is a 91 diesel, 350 000 Km. Australian.
You might want to check that the wiper motor is bolted down tightly. It's on the bulkhead on the PS (Aus). I've seen the cast body break before although that was on a 40, years ago.
It might be worth checking the linkages as well, which are not under the dash, but behind the panel which runs between the windscreen and the bonnet. It's still a royal PITA to get to, but better than under the dash!! There are a few (6 or 7 I think) self tappers along the front edge of it. Once these are undone it will lift out. IIRC there is enough clearance to remove it with the bonnet in place, but not 100% sure on that.
As I said in my post, the linkages are behind the dash ans can not be accessed from outside.
To Scotts HZJ80 my apologies you are correct. had to remove the plastic vent covers to access. Sprayed some CRC at pivot points and now waiting for it to rain in W.A. to see if fixed
You don't have to wait long in WA. We should know soon. Our view in Arizona is that if we are really bad and we die, we get sent to Washington or Oregon where it rains every day. That is our version of Hell!
