Winter front 3FE? Over cooling issue.
I have a 91, weather lately has been cold and I have been having an issue with getting up to temperature.
My fan clutch is original, however is working fine. I can hear it engage and disengage in the summer and when I first start up on a cold motor.
The T-stat is probably the issue as when going down hill for long stretches the temperature will drop dramatically, till I have almost no heat.
But my question is if this is at all normal for the 3FE to over cool in the winter?
Has anyone ran a winter front on an 80 with good results? I am away from any shop access for several weeks. How much would I be looking at to get an OEM T-stat?
What you describe sounds like a thermostat problem to me too. I haven't changed one in my 80 but I have in my Toyota pickup and Camry and they were cheap (around $15) and easy to change (they both had trouble staying warm going down hills too)--I'm assuming the t-stat on the 80 would be similar.
Just paid $42.38 for a new t-stat, gasket, and o-ring, but I get a sweet discount from the dealer. The high temp yellow paint and primer cost about $12
For a temp solution you can run with a piece of cardboard in front of your grill. Since air doesn't flow through the radiator, it warms up much faster, and stays warmer. It's essentially a poor mans manual t-stat.
That seems awfully steep for a spring and a piece of rubber. I'm sure you could find a non-oem t-stat for 1/2 to 1/4 of that price. Start flaming . . . NOW!
Almost guaranteed to be the t-stat. NOT normal to not hold operating temp., regardless of how cold it gets.
Don't forget the o-ring that sits on top of it, and install it carefully. OEM is by far your best bet for everything to go smoothly.
Curtis
Most likely cause is that someone has neglected to reinstall the top seal/oring when they put the thermostat back in at some point in the past. I see it all the time and it is the most common cause of the symptoms you have.
Mark...
This is the patch that I am doing for now. I removed the grill and attached a bit over half of the grill area from behind. This did not make any noticeable difference. Should I cover more and just watch my temps carefully? I am a gauge nut anyway I constantly check them (habit from driving equipment for work).
Don't try to fix the symptom, fix the problem. An '80 will be warm and comfy and a 3FE will run at normal operating temps at -35F and colder. Without blocking off the rad.
You do not need to worry about OEM for a thermostat. Aftermarket thermostat will not let you down any more than a Toyota unit will. You do not need access to a shop to replace it or the gasket/seals. I've done it beside the road in subzero temps. Quick easy job.
Mark...
Here's a price for a non-oem t-stat AutoZone.com | | Thermostat | DURALAST THERMOSTAT and the gasket AutoZone.com | Vehicle Selection | Year. $20.00 and 15 min of your time--problem solved.
Edit: Original post sounded a bit angry. I'm not angry, just trying to help. Cardboard isn't going to do the job but a new thermostat will.
Same thing here, but the PO snapped one of the thermostat housing nuts. So... got to drill it out. Am using the cardboard method until I can fix it, except higher tech. I put it in a plastic sack so it doesn't turn to pulp in the wet weather... :)
Lately I've been covering my entire grill with a towel (which I've been keeping over the windshield overnight to make it easy to see out of in the morning). I've only done it while idling, but wouldn't hesitate to do it while driving at least for a while, depending on ambient temps and how far/fast you are going. Warm up times have dropped from 15 minutes to 5 minutes, so it makes a big difference.
If you have the option, the ideal would be to cover the grill fully until the engine is at normal operating temps, then pull the cover (either partially or entirely).
You could also use a fabric (an old sheet would work nicely) which would block the majority of air while idling or at slow speeds but allow some air through when at speed (though reduced).
The truckers do something similar in the winter as they have a problem with running too cool, though they usually use canvas (more for durability).
You should be toasty warm. Likely a deteriorated o-ring or thermostat issue or both. If you have to go in there you should replace both together.\
Could be low coolant or blocked heater core but I would start with the o-ring and stat...They are usually the guilty party 95% of the time.
With a working thermostat and the seal in place there will be more than enough heat in the cabin to run you out at 0 degrees and 65 on the interstate. I did this last year a couple times acrooss the country and had both heaters on low and was toasty on just a t shirt and pants.
As Mark W said this happens all the time and it is usually the seal in top of the thermostat.
As said above fix it correctly and be done with it. You will be glad you did.
John
Well, just to be contrary.... with my 62 I run a vinyl winter front over the grill, and still have found the need to add some cardboard directly infront of the rad (and more importantly the aux tranny cooler) to keep the engine as warm as usual when it's really cold out (< -25*C). I've never been in to my thermostat, but have never suspected an issue there, it runs plenty warm and consistent till it gets down to -10 or 15*C :meh: Once or twice it's been cold enough out that I've seen the temp gauge dip noticably while waiting for a long red light.
That's a bit counter-intuitive and might indicate a problem. Sitting at a light with no cold air moving over the radiator should increase the engine temperature, not decrease it.
Idling not producing much heat from the engine when it is frigid outside means more heat out than in, that's how I take it. In that situation I would assume there is little/no flow to the rad.
Either way, if the thermostat is working properly, the engine cannot run too cold, given time to warm up. If it is, the thermostat needs to be replaced before it decides to get stuck in the closed position.
Aftermarket T-stats suck balls. Compare the two. Besides the obvious superior engineering clearly visible by comparison, I've had several aftermarket t-stats fail in relatively short order. Never an OEM one. It's not a part that's worth the savings- it can cost you $4000 to replace the engine.
Where I am currently:
We'll say the ambient temperature is 130*C (~230*F) below thermostat/engine temperature
There's a lot of surfaces other than the rad to loose heat across, especially when you have 2 heaters going full blast with the engine idling. Anything you can do to reduce heat loss (like covering your grill/rad to reduce cold air flow into the engine bay) helps when it's frigid. Some people would find the idea of plugging you car in for a few hours before starting it to be unusual. :meh:
That's cold.
