Winter Electric Trouble
Germantown, MD
The truck's been sitting for 2.5 weeks. Usually it give me no issues after sitting for longer then this. However, this morning some thing went wrong. When I turned on the ignition with the DS door open I noticed the followings have no power:
No Ignition chime
No Dome light
No Clock
No Stereo
Every thing else seems to be fine (A/C, instrument lights and etc.)
I'm gonna do a search but this will require some time. So before I tear it apart can any one please point me to the right direction? Where's the fuse for this? Or this is not fuse related...
:cheers:
According to this post the CIG Lighter Fuse that controls the clock, stereo and door buzzer on a 95. Not sure if the 40th Ann. has the same setup; I haven't checked that fues; however, I've got power on my CIG Lighter.
There's a dash control fuse that touches everything you mentioned. I would check all the fuses first and see if they are good, if they are then you will probably need to start checking wiring.
If it's been sitting a while I hope no rodents have made it their home. That can happen this time of year as it gets cold....
I have checked all the fuses (under the steering) in the Fuse Box; they are fine.
I have after market stereo and few days ago I was tinkering with the OEM amp and connected the two connectors that go into it. I had them disconnected because my after market stereo wired up to by-pass that amp. So it seems like I may have blown the dome fuse :whoops:. Is that fuse some where under the hood?
Yep, it was the dome fuse indeed. Evry thing is back online now. Now I have to re-program my blue-tooth and all that :bang:. I'm not gonna be trying this again...
