Winshield Install
High Point, NC Greenville, SC
Ok folks, I used the search and didn't get nothin good, soooo don't flame me.
Onto my question. I just ordered a new windshield gasket from SOR. The cruiser is a '73. Does anyone have suggestions on how to get the key into the gasket once the winshield is in the frame? Is there an order for installation is better than another? I tried re-using the old gasket and the thing was so brittle it just won't work. Thanks for any help.
Hello,
Don't know if you've found your answer or not, but my buddy had a special window installation tool that made this process a breeze! But yes, lots and lots of lube if you do not have the special tool!
The tool made the job literally a five minute process - I think it would be about 50 bucks at a hardware store - might be worth the money to save yourself tha agrevation. And if you're anything like me, I love collecting tools. Best of luck.
Portal_tek said:
If you have a glass company close to you you may want to take the Cruiser down and let them install the lock, they may do it for nothing. There is a zipper tool that will make the job very easy.
http://www.crlaurence.com/ProductPages/C/CP732085_13988.html?Origin=
Scott
(CP762088 CRL Chevette and Pontiac T1000 Filler Strip Insert Tool) This looks like the exact same tool I have. Works great.
Pre-75 can be a one person job. I install the seal on the frame, lube the glass channel only (not the frame channel), slip the glass in a bottom corner, use a hook tool to spread the glass channel open while placing the glass in working from the bottom and around to the top. Once the glass is in place, use this bead lock insert tool to install the lubed up bead lock.
75 and later. 2 person. Rope method. Install the seal on glass. Lube frame channel and rope only (not glass channel) and follow linked instructions in previous post.
I've used nylon cord to install a number of vw windows with the aid of soapy water
