Windshield Wipers Inoperable
Oklahoma
Thank you all for this great forum. It was a great help when doing research prior purchasing my first Land Cruiser. Purchased a 1996 Land Cruiser about 1 month ago and will do a write up on it this weekend. It's bone stock with 122K on it. Tight as a drum, great maintenance records, and is a solid vehicle, in my opinion.
Haven't seen many discussions related to my question and I'm thinking it may not be a common problem.
My front wipers are inoperable, the PO informed that they had been frozen to windshield and haven't worked since.
When I first started troubleshooting, I pulled the plug/harness at the wiper motor and saw voltage with a test light. Then proceeded to pull the motor. The motor's brushes looked rough but functional. Pulled motor apart and found that the magnets were no longer attached to the "can."
Had wiper motor rebuilt and it now functions when a 12 volt source is applied to the outside pins on the top row. (I think pins 1 and 3)
However, when I plug the harness into the motor and move the wiper stalk, I receive no love, and don't see voltage at the harness that plugs into the motor. I swear I had voltage at the harness at the beginning of this, but maybe I'm imagining things.
The FSM instructs to begin testing at a mysterious harness that I believe is on the steering column.
That's my next task, but would like to know if anyone else has encountered this or knows of a common failure point.
Could it be the switch attached to the wiper stalk? Don't really want to pull the steering wheel to do that, but will if I have to.
I hate that my first contribution to the community is a request for help, but I will make more noise when I get the baselining done. The last few weekends have been filled with coolant changes, brake pads, waxing and other preventative maintenance.
Thanks,
Matt
You might start by pulling the plastic shroud on the column behind the steering wheel. Be cautious, as the screws often strip out and cause you grief trying to get it back together.
Keep in mind there's an airbag there on the 96. Might be worth consulting the manual or threads here on working safely around it. It's wiring is generally identified with yellow for caution, so easy to pick it out and avoid.
There are several harnesses there which you can inspect to ensure they're intact. The wheel's tilt mechanism might potentially pinch something, especially is someone was in there working and didn't get things back where they're supposed to be, but if they look good, then most likely it's the switch that's at issue in some way. I'd do some probing and testing on its connector to the harness, as that will tell you if it's there or somewhere in between it and the wiper motor.
Thanks for the advice, I was wanting to avoid the steering column area, but it won't be my first dance with airbags and such. I'm also going to check motor harness and look for resistance changes when moving the wiper stalk. I've seen a few tutorials on testing wiper switches that way.
I'm pretty confident that no one has been in the column, as I am second owner and first owner was pretty meticulous and informs that work like that hasn't been done, but you never know.
It's one of those things that isn't rocket science, but it occurred to me that it was silly to not ask the forums before I really started exploring. Looks like it's time to bust out the fluke and a drop light and get comfortable.
I'll keep folks posted.
Thanks, again
Tonight I was reminded that I can be an idiot. I double checked the harness near the motor for power and saw 12 volts. My apologies for the misinformation. Found that the motor did not operate when connected to a 12 volt power supply on the test bench.
Dismantled the motor and found that one of the brushes was not making contact. Freed up the brush and connected the motor.
Now I have functioning wipers. Still need to play with the aligmnet of the arm on the motor and double check the linkage, but the big part of the project is complete.
Many thanks to greentruck for the advice.
