Windshield polish?
I'm on my second windshield - its about five years old but basically in good shape.
When I am driving in the late afternoon sun, with it at just the right angle I can lots of tiny little pits on it that look like specs of dirt almost, but aren't.
Has anyone used any kind of detailing glass polish compound before (perhaps with an orbital buffer) to eliminate these tiny little marks?
They are so small that you can't feel them with your fingertips, so I think they might go away with buffing.
Thanks for all of your replies!:confused:
MT,
Most of that may actually be pits in the glass. I would like to hear if it can be buffed out.
Also, RainX is a product that claims to help prevent pitting. I'm not sure about that, but I have used it on many vehicles and it sure works well fo rrepelling rain.
I buff and wax the windshield along with the rest of the truck. It doesn't remove the pits, but seems to reduce glare, reflection and makes the wipers work better.
I've tried a few glass polishes, but never felt like they did any good.
Like toolsrus, I wax the glass when I wax, and it seems to work as well as anything.
I've heard of the Zymol before, and used the Rain-X. A friend told me today about Griots garage which sells detailing supplies and he thinks they actually have a glass compound.
If I find some, I let people know how it works.
Thanks!
No practical way to polish those out. They're deep enough you'd need to remove a tremendous amount of glass and it would be beyond expensive to do that type of polishing on glass, then restore it to optical clarity.
DougM
I wish I could get 5 years out of a windshield,
DougM
Actually that isn't totally correct; it is true that you can't remove the good glass to the lower level of the chips however you can put polish to the chip's cavity so that they are as smooth and shiny as the good surrounding glass and therefore making them much less visible. Eastwood makes products for this and they work well. It is labor intensive and more intended to restore those windshields that are no longer available, however it is possible and practical. HTH. :cheers:
The Colorado DOT uses "sand" on the roads but in reality, it is closer to 3/4" road base. We've had snow six weekends in a row and the glass companies are going to be very busy this spring. Two or three years for a windshield is average life here if you are lucky enough not to have to deal with cracked windshields before then.
Eastwood has a number of items to polish glass here.
Worth looking into. I haven't used this particular items but everything I have used from Eastwood has been top notch,
Eastwood stuff works, just FYI. Be careful though, you are removing glass with it.
