Windshield Harness Clips
Atlanta
What are the best clip sources on the <74 high-mount wiper harnesses?
Dealer says the clips are discontinued.
These are so visible compared to other locations that I'd like them to be as accurate/stock as possible.
Also, is there supposed to be a grommet here where the harness exits the frame?
Thanks!
I got mine used. Either SOR or CruiserParts.net, I cannot remember which. I cleaned them up then shot them with some plastic coat.
Yes. Cannot remember if I went OEM or not. Worst case, measure the hole and pick one up at your local ACE. Just split it to install. I put the split side down. Looking at the parts diagram, it might be: 90480-10300. The website below lists the diameter which you can measure to make sure.
