Windshield glass replacement
Who's had their windshield glass replaced? How much is the gasket (and where'd you buy if from), and what did the glass shop charge you to cut the piece and install it? I need to replace mine, but I want to make sure I don't get ripped off.
The last FJ40 windshield I replaced (about a year ago) was purchased from the Toyota dealership for about $70 for the glass. (It took them a couple days to order and get it in.)
Fortunately my gasket was still in good shape. And, the DIY installation of the windshield took about 10 minutes with the old 1/4" rope trick.
When I had mine done a few years ago, my gasket was really bad, so I bought a new one from SOR. It turns out that it still needed to be cut, so I probably could have had the guy use a generic replacement.
I paid $75 for custom cut glass and installation. I don't even want to remember how much I paid for the gasket...
Ive replaced mine several times. If there is enough of your old windshield left, take it out of the rubber, lay it out on a sheet of paper and trace it. Take the tracing to a local glass shop and have them cut you one out of flat lami. I have never paid more than $35 for the glass. If your rubber is still OK, take the glass home and install it yourself. Just soap it and rope it, its as easy as can be.
When they are done cutting your glass, get the template back from them, roll it up and put it in a shipping tube in the garage somewhere. That way when it happens again, you already have the pattern.
Hodag
Great idea about the template, while I was at the glass shop I would have them order an aftermarket gasket, shouldn't be more that $25 or so.
NJFJ40 said:
Its in the Tech section on this board - http://www.ih8mud.com/tech/glassinstall2.php
Yep, that's the trick. (I originally stole the idea from an installer about 5 windshields ago.)
Even though the Tech thread says 1/8" rope, I've had even better luck with 3/16" - 1/4" nylon rope. It's a little harder to stuff into the gasket grove. But once it's in, it flares the lip of the grove open even wider for easier windshield alignment and allows for one-person installation. Just make sure you start your "rope peeling" from the bottom, so gravity will help the windshield seat itself.
Works great on hardtop side and corner windows, too. :cheers:
