windshield frame swap
Winston-Salem, NC
ok all I need a little help. I am replacing the windshield frame in my 79 FJ40. It was involved in a rollover from the PO. I am replacing with a windhield frame from a pre-75 cruiser. It has the wipers mounted on top but I do not know the exact year.
Do the hinges match up for the swap or will I need different ones. I still have the ones from the 79 but they do not seem to line up. They did not look to take too much of the damage during the roll over but I could be wrong.
I'm sure the wiring will be a challenge as well but that's another story. Thanks in advance for the help.
a fellow cruiser is running a later WF on his early 40...
I think as long as you run the hinges that match the WF you'll be fine.
Make sure that the cowl is not tweaked. You would be surprised where the energy goes in a rollover and the things that get damaged that are not obvious, until you dig in.
Good luck!
-Steve
good idea Steve. Thanks. Well using the calibrated right eye I did not see anything, but we all know how accurate that is.
