Windshield creaks.
Sonoma, CA
Website
www.myspace.com
I had my windshield replaced about 6 months ago due to a truck making a nice crack after kicking up a rock.
They screwed up the installation so it leaked.
I called them back about a month ago, and had them fix it. It stopped leaking.
Then this weekend, I went to Surf N Turf, and drove around in the dunes for a bit, and then came back to my campsite and ate lunch. The next time I headed out, I heard a weird creaking noise. I thought I screwed up an axle or god knows what, but I realized it was coming from up higher than underneath the truck.
Now whenever I drive over about 50MPH, the sound of the wind is pretty damn loud, and it the windshield creaks whenever the road I'm on isn't completely flat.
Has anyone had this problem after a windshield replacement? Because it's really starting to piss me off. :mad: I guess flexing might have caused it to pop the gasket out of it's place or something, I've no idear.
Thanks in advance.
If it is actually coming from the windshield, my first guess is that they did not use the proper adhesive and/or put the adhesive in the right places. Odd though, cause that would seem to indicate that your body was flexing ? more than it should? (??check body mounts?). On the other hand, I recall talking to a windshield safety/installation expert; he was the head of some national automotive windshield installation association (forget his title). He mentioned that the integrity of the windshield is calculated into the equation for crash protection,etc. So, maybe if it is not properly installed,there could be more body flex that normal? (brain storming here).
When my windshield was replaced a few months back they used NO adhesive whatsoever, so it leaked like a sieve until they came back and did it again. But it never creaked.
(disclaimer: I am not a body flex expert, windshield repair expert; in fact, I am not an expert in anything having to do with anything automotive)
g
g
Don't worry, we're in the same boat. I didn't think of it til just now, but it might be from hitting bumps too hard and knocking the gasket out of place. From the impact of hitting the hills to get enough speed to get up the sand.
It's not from knocking anything out of place. The gasket is supposed to have adhesive holding it to the glass and the body. Either yours doesn't or the wrong adhesive was used.
Yes, the windshield is a structural component of the vehicle in modern times.
-Spike
I'll bet that your windshield leaks now again as well. Try running a hose on the windshield to see. It's probably not sealed anymore for whatever reason.
These threads come up all to often. I'm now glad I decided to install a the windshield myself (with some help) after my fiasco with the windshield shop. It's not pretty but it's sealed.
I had my windshield replaced 6 mos or so ago and now that it is cold in the mornings... it creaks too. They installed it -then- went through with the black caulk sealing stuff in a tube trying to push it under the seal. Not thrilled with the install. They didn't even want to put sealant in it at all.
Does anyone have the spec on what sealant SHOULD be used?
The installers MUST use an Adhesive; the key word being adhesive; to keep the windshield in place in the event of an accident. It is also a sealant, but it's main job is as an adhesive.
I wrote a long post awhile back about my fiasco with an installer.
The main points are that the metal must be primed before the windshield goes in to prevent rust under the gasket, and then the adhesive must applied according to the FSM.
Only afterwards if there is a leak do they use a secondary sealant.
Sunstar 9002 T primer or equivalent
Sikaflex 256H adhesive or equivalent
(Google Sikaflex, they have a website)
g
If your windshield is creaking - and I have no doubt it is because one of mine did the same thing and it drove me to the edge before I figured it out - then it was improperly installed. Without going into too much detail, w/s installers are generally unskilled and have very little knowledge about what they do because the job is low pay and temporary. The adhesive adds some complexity to the install that they all want to avoid "because it's not needed anyhow...". Yeah, right.
Your w/s is supposed to be glued both to the rubber gasket, AND to the body. If you finally talk them into it, they'll just put glue here and there rather than a continuous bead just so there's some glue evidence here and there to shut you up. That means they have to clean the gasket (more time, more complexity, they will simply tell you you need a new gasket - more bs).
Getting a w/s installed properly on an 80 is a challenge because the industry is set up for fast poor installs and thin margins. Best to ask to speak with the owner and explain what you want done and have them come do it on a day or place where you can actually watch them. If you sense the owner is uncomfortable, just hang up and call the next place down the list until you find someone who has a clue.
Someone above correctly surmised that your w/s is now leaking somewhere. Two edges that are sliding (creaking) means water there will simply drip through. Members here have had HVAC components destroyed ($), CPUs damaged ($$$), moldy interiors and carpet and all manner of unsolvable dash electric issues from this water source.
Should it pop loose while four wheeling? Absolutely freakin' not. You should be incapable of breaking your windshield's glue seal loose short of a heavy collision distorting the roof. But they'll tell you "yeah, if you drive on rough roads, or offroad a lot they'll break loose and that's your fault...". Total BS. Demand your w/s be properly installed.
DougM
Been there done that. My leaky windshield took out the kill switch relay in my RS3000 alarm. Without the relay, the truck wouldn't start.
When the installers came out for the second time, they spent about an hour and a half doing whatever it was that they were doing. I didn't watch, I had to do some stuff.
It's not leaking though, which is the weird thing. I went through an automatic car wash right after SNT to get the salt and sand off, and nothing leaked, and then the next day when I got home, I took it to the hand car wash, and sprayed all corners of the windshield for a good amount of time, scrubbed the windshield to get the bugs off, and then sprayed it some more.
I'd assume that it would leak though, cause it's really windy. I'll call up the place Mudrak recommended when I get some cash. I had to use the place AAA told me to.
I should have realized that when I got off hold and the AAA agent and the guy at the windshield place were arguing really loudly that it should be a red flag.
