Windshield bolts and rust
Western Slope, CO
I don't think the top has ever been off my 40. I took it off and seems that the winshield bolt on the drivers side is rusted up, tried wd-40 for a couple days and no luck. Should I just take a big hammer to it or what?
:eek:
If you have the top off what are you trying to do now?
Be more specific on windshield bolts.
Nocents
I like to lay down the windshield
Undo the two hold-back Knobs/bolts on the inside, spray the hinge piviot again then climb on the hood and pull it down!
Nocents
I can get the passenger side knob loose, the driver side won't turn by hand. are these cheap to replace if I break it?
:confused: :confused:
What do you consider cheap. I would plan on about 20 bucks as usually they come in a set and not seperate. But you may be able to do better..............
:cheers:
Not to hijack, but what do you recommend doing to the top two hindge bolts? I can't get in there with any PB and they will not turn at all. I guess water coming down the windshield frame really rusted them up. If I try to turn the screws, I think they sill strip before the rust breaks loose.
on the hinge?....get a torch, heat em, then whack em with an impact driver.
use a drill/driver with a bit...worked for me
Just fought with mine a while back, real PITA getting all the bolts out of the hinges and frame - lots of patience, lots of Shaeffers penetrating oil, a few good smacks with a center punch and then all but two came out - the drill then easy out took care of those :D
Looking forward to getting Shanes stainless kits when I go back together with it
Not to highjack the thread, but what is the Shanes Stainless bolt kit?
Where do you get them and how much?
Now back to the regularly scheduled thread......
Finally got my hinges off. Here's the score: 11 screws removed
4 screws drilled out
1 screw snapped off
2 impact driver bits destroyed
1/2 bottle of Mapp gas used
About 1 gallon of PB Blaster used (soaked them for
about a month) Proably not quite a gallon
The heat made all the difference in the world.
