Windshield angle
I am installing a new role bar and want to figure out how close I can get it to the windshield. My Hard top is in pieces so that won't help. What angle is the windshild suppose to be at? Are the hidges almost straight? Or how far bent? Thanks for your input.
Mt STC soft top required(IIRC) 80 1/2" from the top of the WS frame to the top of the tailgate, that turned out to be the same as for a good fit to my hardtop, although a little difficult to measure with the hardtop on.
Ed
i dont know the exact angle but 10 deg. sounds close. is your windsheild frame atached or ? the hinges are opened (or closed depending on your train of thought) to were they would be flat if placed on a smooth surface. i included some pics i hope they help you!
Ditto
they should be even/level/flat...
Do you have the big rubber gasket thing between the frame and cowl?
Ed
This method works.
If you have a hard top do you have hard doors? If you do mount the doors and make sure the gap is even all the around the tub, then make sure the windshield lines up to the doors. If you have the spacers that fit around the knobs that hold the windshield in place this will get you close but not perfect.
John
I guess I didn't make it clear to my sure the gap is the same between the door and the tub all the way around.
If your doors are sagging just replace the pins and bushings in the hinges, SOR sells the parts for around sixteen dollars (plus shipping and handling of course). Loosen the bolts on the door adjust and tighten. If your door openings in the tub are still square this should work without any problem.
John
