A fellow mud member has a window washer assembly for sale that i am interested in buying. It is from a 79. I know sor and ccot sells the aftermarket version of them, but they don't work with the factory switch. The only problem with the window washer assembly is that he is not sure if the pump is working or not. Now here is my question, if i buy this and the pump doesn't work, is there anywhere i can buy a replacement pump, can it be prepared, or can i use the pump from after market ones that ccot sells? Thank-you.
