window troubles
On my 89 my pass. fr. window has always been slow going up or down. today it wasn't going up but would go down, also making a really loud straining noise. now it won't work at all. I have no idea when it comes to power accessories.
Chances are you tripped the circuit breaker for the windows. Under the DS dash there are two circuit breakers that can be reset - one's for the windows the other (I can't remember - possibly for A/C). Look for a cylindrical aluminum thingy with a hole in it - it should have an embossed "Reset" next to/under the hole. Use a tooth pick or similar to reset the circuit breaker - you'll hear a click as it is reset.
As for the window, remove the door panel and clean or replace the weatherstrip/window channel. Chances that over time it's full of gunk or dog drool. Straight silicone spray after you clean should help.
Good luck
Thanks guys. I tried a better switch last night. to no avail, but 12v straight from the batt. worked, also that groaning sounded horrible. are there any of those stupid little pastic washers in there to go bad?
No, none of the "stupid" washers. Just years of gunk in the motor, electrical contacts and widow channel.
The DS front window only has a single switch on the "master switch" along w/ a relay for the "auto down" feature that's tucked inside the door skin. Sounds like the switch contacts are worn - you can try cleaning/dressing them or replace the master switch which is around $180 new. If you use search you'll find an example w/ photos on how to dress the contacts.
A little oil on the shaft of the motor certainly won't hurt either - and do clean the window channels.
