Window Smashed!
Broken in today :(
i wouldn't think that it would be much harder than a 60 series, if so, mine was easy. only about $25 for the window from the dealer.
I just had this happen to me today (june 29, 2008), made a search and found this thread. The car glass place wants... Hold on to something... $450 (before taxes) PLUS a week for delivery!
To those who have done it, WHERE can this elusive piece of glass be found for only $40???
I've gotten myself some plexiglass, the rubber weatherstripping is in excellent shape, I believe I can make a good repair for a while with a piece of plexiglass until I find an OEM piece of glass at a reasonable price. I just need the dimensions of that piece of glass, so I may cut the plexiglass to the proper size.
Also, is there a specific technique to put that thing back in? A buddy says I need a rope and some grease to fit it in... I've never done that before, just trying to figure it out...
Finally, does anyone have a spare piece of glass for sale ?
Thanks!
Thanks ;)
I'm slowly figuring it out... Got to have it fixed by 8AM tomorrow morning...
For those who want to fix their window themselves, here's a couple of pointers:
- Remove all pieces of broken glass and remove existing weatherstripping. Then use a piece of stiff cardboard as a template, basically the glass has to be about the size of the opening, or slightly (2-3mm) larger. Larger, you can file or sand the plexiglass down, but it's easy to melt it if you use a power tool.
- Dimension is critical (+/- 3mm). Slightly too big, very hard to install. Slightly too small, loose within the weatherstripping and possible not watertight. You can cut the plexiglass with a jig saw, low speed, non-orbital, bidirectional fine tooth. Go slow, takes maybe 15 minutes to cut.
- 3mm plexiglass is OK, but slightly too thin. OTOH, it bends easy. 4.5mm plexiglass would be more solid but is slightly too thick. I haven't tried with 4.5mm plexiglass.
- Remove the main window guide screw on top of the door, behind the weatherstrippping, then lower the window. Also remove the horizontal window wiper. I used cream hand cleaner on the rubber to make it slide in easier. All these measures allow easier insertion.
- If you want to 'upgrade' to plexiglass, consider this: they are the favorites of thieves because of the way alarm systems are installed. If you use plexiglass, it may not break, which is good, as the thief may get discouraged, but if he insists he could smash a more difficult to replace/more expensive window. Also, the plexiglass is clear and flat and won't resist scratches, while the window is often tinted and is properly shaped and is scratch resistant.
- If you can find glass cheap (let's say $40), go for it, it's fairly easy to do. My deductible being $100, I'd rather do it myself and avoid making a claim that may affect my insurance rate. Trouble is, here in the most highly taxed jurisdiction in North America, they want to charge $450 plus taxes for the job!
- If anyone in the North East has a spare piece of glass (left side / US driver side), please let me know. I'll be in Maine mid to end July ;)
I am no expert, but I have installed a window before using the following steps:
-Install the seal on the new glass,
-Lube outer grove of seal with vaseline where seal will contact door frame
-Place dental floss or equivalent in the groove of the seal all around the window while leaving some to hold onto
-Have some on the inside push the window into its location while you pull the string/floss toward you. The seal will begin to snap into place as you work the string/floss around the window frame.
Best of luck!
It's easy to replace that glass. You don't need rope, grease, sealant or anything. But you do need a FSM if you have one. It'll tell you how to do it. It's kind of like a jigsaw puzzle trying to get it in there correctly and it is a very tight fit, but it's not too difficult. The local glass installer wanted $250 but as I said, I got the glass for $40 at the dealership.
Thanks!
let's see a) right here and b) yes....
...which one you need DS or PS.
edit: just saw this ...
...if you can get it at the dealer for $40 i'd go that route so
you don't have to wait for my lazy ass to get to the post office.
Thanks million guys, I'll call Prime Toyota tomorrow :)
I have replaced this window before in my 97. I was very supprised at the low price for the window and seal from the dealer (together under $50). As the diagram shows the key is the screw on top of the door. Once this screw was removed it was simple on a 97. Before I replaced it with the OEM part (correct shade of glass too) an after market one was installed and it made alot of wind noise.
