I'm replacing the window runs on my 1990 62. I got new ones front and back from toyotapartsdeal.com. The rear worked perfectly fine and accomplished what I had hoped, the window is tighter and goes up and down much faster. The front don't appear to be the same as what I removed. The forward edge ends a couple inches above where in goes into the door. The old one was a good 6 inches longer on the forward side, the rear or posterior leg is a little longer but otherwise ok.
Has anyone used these?? There are supposed to be factory and the labeling looked toyota.
I could easily install them and just not push the second part down as far into the door so they butted together where the other ended. I'm just not sure how well that would work.
Appreciate any ideas.
