Window electrical problem: One side stopped working
Vancouver, BC
Last week I noticed that the left-hand side of my truck's windows (passenger side as its an RHD) all stopped working for no apparent reason (Left front & Left Rear). I would greatly appreciate thoughts on where to continue my troubleshooting efforts.
I checked the Driver master switch continuity in all the positions and it all checked out, so I dont think its the switch itself. I checked the main loom from the door under the driver kick panel and it seems intact.
Oh and yes, I checked the fuses too.
It just seems weird that 1/2 the windows pack it in. Any thoughts or suggestions are greatly appreciated.
Ah! Well, I finally finally figured out what was going on with mine. The PO had installed larger guage wiring that had additional fuses. Those fuses were linked to the IG circuit. And the IG circuit was shorting as soon as the key was turned..... all because of a very complicated alarm system. Hacked out the Alarm , replaced the fuses and all was well again!
Too bad I already spent $200 on both front and rear window motors.
I ripped out a viper alarm system. I wonder if my problem is the same. I ordered a new driver side master switch for the windows. The problem still exists! Where are those fuses located that you found?
