EDIT: in the end the problem is the regulator itself, not the crank, so the only solution is to replace the regulator. Admins you can delete!!
HI Everyone, I recently replaced the original plastic windows cranks with some cool looking metal ones and my vanity has been punished because "metal vs metal" slowly filed the teeth of the regulator and now the crank slips and the windows can't be open. I bought new cranks but they also slip. My garage is looking for a replacement and from ebay it would take 1 month to have a new regulator mechanism. What do you suggest in the meantime as a grandma remedy to have my cranks not slipping, while waiting for a long term repair?
I was thinking of putting small pieces of wood matches inside the hole of the crank to have a tighter grip on the regulator "male" or some kind of glue that still will allow me to remove the crank if I need to open the panel.
Do you have any better DIY solutions?
Thank you!
Thank you!
