Window closes crooked
Alpine, CA
Window alignment
Hi folks,
My 82 FJ40 passenger window doesn't quite lign up straight when closed, ending up tilted slightly forward.
Is the window alignment adjustable?
Thanks,
John:hillbilly:
Yes, inside the door at the window track. The window regulator itself has 3 or so bolts holding it to the door, some of these are slotted, roll up the window and then adjust the regulator for the tilt.
check the window tracks as well, when they fall aprt or get worn that window will not close properly.
