I've fixed mine a week or two ago. This is what I did. I took off the panel, took the track out, and pulled the "black rubber" seal out. I cleaned it off really good and dried the "inside" of the rubber seal off the best I could, to make it "sticky". I then sprayed the outside of the rubber seal down with a silicon based grease, and placed it on the window. I then took the track and while holding the rubber seal, I began pulling the track on to the seal, I took my left hand and used it to keep the seal from slipping forward, working gently, but tough, pushing back on to the track when neccessary. It came back to specs. I then ensured that I had the rotation right for the track to go up and down, without falling off again, about a 1/4" off the window edge. And to ensure that I didn't get any grab from the window seals, I sprayed a silicon base lube on the track. The window works smooth as silk now. Best of luck!
