Winch solenoid amps
Hi there, is it ok to use a 400amp solenoid with a winch that draws 430amps (max) at 12000lbs?
Thank you
Probably. The highest amperage draw for a winch is usually at start-up under load, and only lasts for a second or less. Solenoids and contactors are rated for how many amps they can carry for so long, if you look at the charts they can handle way more than their 100% duty (continuous) rating for a short time like start-up.
Excellent, I will try it.
Thank you
