Winch mounting
Powell River, BC
I need to modify my front bumper a little bit, I think just to cut out a little bit of the top skin near the winch cavity, to fit my fancy new unit :)
Anyone nearby be able to give me a hand doing this. The plate is (going off memory here as I'm at work right now) is 3/16" or 1/4" thereabouts, and I don't have anything to cut that, nicely at least.
Gees , what is happening to cruiser heads? :bang:Long ago all they could afford was cheap beer as everything else was going into parts.
Now it's wine and probably single malt Scotches.:grinpimp:
Well have to agree mod the rear and mount the 8274 in the front
On my willys have a m 8000 on the front been used 2 times
The old bellview in the back gets used all the time
And will be changed to a 8274 when I put it back together
2plus years later and I finally got around to installing it. And it even works!
Night time stealth photos, 'cuz it's a TJM stealth winch....
It turned out to be slightly easier than I originally thought, still took 8 plus hours though. I had to add 4 new mounting holes about an inch or so lower than the existing and trim the bottom of the cable cut out. After partially removing the grill, I decided to remove the bumper to get it on with the solenoid pack in the original position. I debated moving the pack into the engine bay, but since I had no extra cable I left it as is.
After a little research about which battery to wire it to, I ended up wiring it to the starting battery as the general internet consensus told me this was more prudent because of loads/relays/electricalmumbojumbo.
Had to buy new bolts, the ones TJM supplied with it didn't seem to factor in any mounting plate thickness.
The wireless remote is pretty cool, I can see that being quite usefull.
Still have the 8274's apart on my bench, I'll get to them again one of these days.
