Winch control location? in cab vs. external
Curious to hear some feedback on this. I recently dropped a Superwinch epi 9000 onto my ARB, and I have to relocate the solenoid. Currently I have it in the battery tray, and am floating ideas for the external plug.
One idea was to drill a small hole in the flat top of the ARB bumper on the drivers side. Just to the left of the hoop support (facing vehicle) This would provide a clean look and place the plug close to the winch.
The other, is to rewire and run the controls into the cab and utilize the antennae up and down switch. Not sure how to wire this, but have seen it out on the forum.
Anyone have any thoughts on drilling a small nickel sized hole into the ARB to mount the plug???
I mounted my relay control box ahead of the battery on the driver's side and extended the control plug wires to attach thru the ARB right where you mentioned. It looks great and functions perfeecctly. The main thing is to protect the relays and get that big black box out from in front of the radiator airflow. Of course I had to get 3 longer 2 AWG wires to run from the control box to the winch motor.
Good luck and dont forget to paint the hole you just drilled to prevent rust.
