winch cable
Southern Ontario, Canada
Can one change the OEM Toyota cable with synthetic rope?
On the OEM winch the cable is held on the reel with a plug off to one side of the reel not a bolt on the reel.
Yes I did a search not much talk.
I have a HDJ81 from Japan 1991
Having no idea since i've never seen a OEM winch i'd say any good fab store or 4x4 store should be able to do the swap easily.
Can you post a pic up of it
The reel side shows the cable fitting that is outside the reel where a
typical reel the cable would bolt on inside the reel.
The cable end is a pressed on collar that slides into that fitting on
the reel so when all the cable is rolled on th reel that end sits on the
of the reel.
Does that make sense.
