Doesn't look factory... 15" rims generally won't fit on an FZJ80 due to the rear discs, but less backspacing (or wheel spacers, whatever floats your boat) will help.
See if you can figure out the backspacing, or just test fit them (if possible). The latter will be the true judge of your decision.
If that's corrosion and not, um, decorative, I'm not sure sure that is something I'd want to be rolling around on.
The spare the PO left under our 80 looks something like that and it won't hold air. Probably a good thing, as I'm a lot less tempted to put it on my truck.
There's one good OEM rim and three more that are, well, somewhat better than the spare that came as part of the deal. They hold air and doesn't inspire the trepidation that the spare rim does.
Sounds good. I didn't think they used all that *#$*@! salt north of the border like they down down here. It's heck on rims and undercarriages. If people need to get out a drive before the plow gets there, they should buy a 4x4.
From the picture, it doesnt appear to have a large enough center bore IMO. Check it out and see if it will slide over all the way down. Then check your lug nuts - you will need acorn types probably (?) for that wheel vs the shank style your LC has. The acorn nuts wont grab alot of thread though....be careful as you proceed.
