Will these 4 speaker fit?
[FONT=Arial,Helvetica][FONT=Arial,Helvetica][FONT=Arial,Helvetica]Will these fit in the front and rear doors?
[/FONT]
[/FONT]
[/FONT]
(39.95) MB QUART FKA-116 (FKA116) <br>6.5" 2-Way 150W '08 FORMULA Series Coaxial SPEAKERS
SPECIFICATIONS
  • Speaker Size : 6.5"
  • Design : 2-Way
  • Power Handling (RMS) : 40 Watts
  • Power Handling (MAX) : 150 Watts
  • Sensitivity : 88dB
  • Frequency Response : 50Hz~32kHz
  • Impedance : 4-Ohms
  • Mounting Depth : 2.6"
  • Approximate Weight : 5 LBS
[/FONT]
[/FONT]
[/FONT]
They will fit in the front with a speaker ring/spacer. They will not fit under the stock grille. I made speaker rings out of 1/2" plywood. I used 2 on each speaker for a 1" spacer. Then, I cut the stock hole in the door panel for a bit larger diameter. I left the vinyl uncut to cover up the speaker rings. I can take some pictures later, if you would like.
Not at all, but I am not using any grilles. I have the same speaker frame, as mine are MB Quart Q series 6.5".
I would really like to see the install of them. You got those pictures?
I am having some camera/phone issues. I will post them as soon as I can.
