Will not start!!!
Recently acquired a 1984 fj60. Getting fuel to carb, solenoid getting voltage and clicking. Carb not taking on fuel/no fuel in sight glass.Will not start on her own. Starts and runs when fuel/starting fluid sprayed into carb. Replaced original carb with rebuilt stock carb, same problem! Located in South Central Missouri (Ford/Chevy country) Need some help! Can anyone point me in the right direction? Thanks, nu2yoda
If you know the carb is getting fuel, pull the top of the carb off and check the float needle/seat. There also may be a screen inline before the needle/seat, thats clogged. See if the fuel inlet on the carb can unscrew.
I only know about 22r carbs(PU truck), and I've never worked on the insides of a LC carb. They maybe similar.
I'm not exactly sure to either question! It's getting good fuel at the carb. But the crb will not accept it! Check for clogs, etc. Will need to pull the top off the carb and check it out. I'll check the fuel and the pump too! Thank you for responding. I'm new to this and I know it will take time to learn this set up!
OK, Took the top off carb and it was gummed up. Cleaned it up and replaced it then she fired right up! Still some idiling issues to deal with , but she starts and runs on her own! Thank you very much!
If the upper was gummed up, you can bet the middle and lower are dirty also.
I'd go to Rockauto.com and see if they have a rebuild kit for it.
You'll feel better if you just do it right the first time.
