Will it fit?
Sure, why not, its just a big block. Anything is possible with alittle help from a cutting torch / welder. Might have to massage a few things but if someone on here put a Mercury 502 in a 60 series, anything is possible.
Sheesh Darin, going big I see. I've seen a 440 in one before. Like you said though, with a little massaging and creative metal work you should be able to.
ran a 501 caddy for years and it fit and worked good alittle tight here and there used stock caddy rad had to notch inner fenders for fit engine had 500ft lbs of tourqe at 2400 would idle up anything good luck with yours
john0089 said:
Will a 8.1L Vortec V-8, 502 physically fit into a fj40? Anybody ever tried it?
Have installed a big block before. A little tight but fit. Did not use headers and did not use a clutch fan for extra room.
I have seen several folks using BB chevy engines, but I don't know exactly how the fit was, it is just a question of time and labor. $$$$ if your going to pay someone to do it.
I will say this though, I never, never had anyone sniff the tailpipes on my BB pontiac firebird and trans am except for a BB chevy! Fords and Mopars included you just can't beat that engine for footpounds of torque and equal HP. One of the finest engines every built. If you do enough research on it you will find that it was designed by prior GM pontiac engineers as the GTO's were kicking the crap out of the Corvettes. That engine has a very interesting history.
Good luck with your BB bowtie.
