I'm preparing to install an Innovate Motorsports Wideband AFR gauge - now trying to figure out exactly where to put the wideband O2 sensor, and in what mounting configuration, given my EGT concerns that started me on this path. So, I'm wondering if anyone has experience or advice with such an installation. I see 1500 deg + at 65 on hills under 7 psi boost, with the EGT probe mounted 5 inches down from the mounting flange on the forward branch of the downpipe Y.
This is just another step in my slow investigation of why my EGT seems to be high across the board - so high in fact that I may be out of limits for the wideband O2 sensor, per the following warning in the installation manual.
"The maximum temperature of the sensor at the bung (the sensor hexagon)
should not exceed 500 oC or 900 oF. If these temperatures are exceeded in your
application you should either install a copper heat sink (instructions below) or the
Innovate Motorsports Heat-Sink Bung extender (HBX-1). The bung extender is recommended for situations where airflow is restricted or the encountered heat is higher than a heat sink can handle."
Here's the IM catalog entry on the HBX-1: Innovate Motor Sports On-Line Store
Here's the instructions for fabbing a copper heat sink (but no mention of how much heat it can handle):
"Use a 4” x 4” (10cm x 10 cm) sheet of copper sheet metal 14ga (1.5mm) thick. Drill a hole in the
center with the same diameter of the oxygen sensor threads ~3/4” (19mm).
Fold the sides up 45 deg and mount it between the sensor and the bung like you would a big
washer. Orient it such that the sides are exposed to good airflow."
The new sensor bung will have to go onto the exhaust collector ahead of the existing front O2 sensor, about 18-20" downstream from my EGT probe. What I don't know is, will the EGT at that point be below 900 deg F, worst case? It looks like there is enough room to stack a short bung, then the copper plate heat sink, then the O2 sensor, between the collector and fenderwell, oriented outboard and slightly rearward. I'm not sure about room for the HBX-1 extender - have not called IM to ask how long it is so I can make a mock-up - but it would probably add at least 2.5 inches and that may not fit.
Even if there is room, I wonder about functionality. In that location directly behind the tire, it looks like the small annular "fins" on the HBX-1 would get clogged by mud at the first splash, and it's heat sink function would immediately cease. A copper plate heat sink would also load up with mud quickly, it seems to me.
BTW, I replaced the cats and that only reduced the avg EGTs by 50-75 degs. I did a HG & valve job last year (2,500 miles ago) and saw no indication of detonation damage, burnt valves or piston pitting, and the truck never pings or knocks. I run Rick's MAF (FPR disconnected from Vac), and Iridium plugs one step colder than spec. I had the injectors done and replaced the entire engine wiring harness. I went from a 1600 deg analog EGT gauge to a 2000 deg digital (both Autometer) and the EGT readings were consistent before and after the head work. I also run the 3.0 fan, brass rad, blue hub clutch with thicker fluid, an aux oil cooler, and have never seen water temps elevated at all in this cool climate. I get 11-12 mpg pushing 33" tires.
Maybe this is just a neurosis brought on by staring at an EGT gauge too long, but I'm determined to find out if high EGT is due to a lean condition - and I want to do a good installation of the wideband O2 sensor and not burn it up every 10K miles.
Appreciate your insights.
Thanks, Mack
Thanks, Mack
